WickedJester
I have a question regarding determining the ultimate vertical loading of a wood beam.
I have testing data to start. In the test its three planks of wood that are layed horizontally on top of each other. A balanced horizontal longitudinal load is applied simitaniously at 4 locations on the beam and the beam is fixed in the middle. The horizontal load performance and ultimate strength were determined.
Data is represented as pounds (load) and inches (deflection). The size per plank is 1.75"x7.25"x118".
I have not does these clacs for awhile and not sure where to start? Is it possible to infer my ultimate vertical loading strength from the ultimate horizontal loading strength?
