I'm designing an infiltration bed to take roof drains for a new house. I'm fairly green with this process.
The bed will consist of perforated pipes in a gravel bed wrapped in geotextile.
If some of you could provide tips on potential pitfalls, I would greatly appreciate it. (aside from the fact that I should provide an overflow and oversize the thing to begin with.)
Also, I can use some help in designing the outlet structure:
Larger storm events will empty into the public storm sewer. I plan to use a riser with orifices. Do any special measures need to be taken to ensure that there's no siphon effet (and if so, would providing a vent in the bed, just before the outlet structure do the trick--assuming that the outlet structure is also ventilated)?
Thanks for your time!
