infinite or none? does a circle has infinite corners or none? 5
Spoonful
175
Hi All:
I guess this could be a interesting or pointless discussion?
Can we say a shape with infinite number of corners, if it is not infinitely large, it has to be a circle? Then it becomes have no corners?
If true, how can one from linearly increasing number of certain property (in this case corners) to become none of that property?
Since this is an engineering site I'll say that a circle (or any other smooth curve) has a finite number of corners, for any desired level of precision.
Doug Jenkins
Interactive Design Services
Your premise is not correct. A circle is approximated by a regular polygon with an infinite number of vertices, which are not necessarily "corners" since "corner" implies a right angle. As the number of vertices increase, their included angle increases, until every vertex becomes a straight angle, which is the limiting case for the circle, and why tangent lines intersect at only one point.
The interior angle of a vertex is given by 180 - 360/n = 180 * (n-2)/n where n is the number of vertices. The only regular polygon with true corners is a square. As n goes to infinity, the interior angle approaches 180.
TTFN
faq731-376
7ofakss
Sorry to be pedantic, IRStuff, but as far as I recall- as per definition, tangents intersect a circle at two infinitesimally close points.
That's exactly the same thing.
Per definition: 0 angles
for any practical use: finite number of angels.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
@wolf ... ? a tangent touches a circle at one point.
i guess if you constructed a cirlce from a single piece of stuff (from a single line element) by bending it ... then it'd have no corners (or verticies)
if you constructed it by increasing the number of corners (or verticies) (like strethcing a piece of string around pegs) then it'd have an infinite number.
now i'll ponder the imminent end of the world (as we know it)
Well, rb1957, I know a proper mathematical definition of a tangent, otherwise I wouldn't presume to correct as knowledgeable and respected member as IRStuff. You may choose to adopt more practical, if less accurate, interpretation but... The definition I gave is as far as I know the only correct one (for all curves, incl. a circle) and if you look at it more closely it will lead you to a more recognizable, derivative form.
sorry wolf but every definition of tangent i know says a tangent touches a circle at a single point.
my memory thought of it that way.
a google search shows links to many definitions that say "touch" and "single point".
do you have a link that says "tangents intersect a circle at two infinitesimally close points" ?
OK, I'll look it up rb1957- but I'm positive it's the definition I was taught at high school (math oriented gymnasium) and at college, as well as my grandfather, who was college professor of descriptive geometry, using it...
What is a corner? A corner is a C0 discontinuity. Circles are C2 continuous (C2 constant, for that matter). Mathematically, circles have no corners.
(x-a)^2 + (y-b)^2 = r^2
Anyone blathering about the approximation of a circle is simply not talking about a circle, but an entirely different shape with an entirely different definition, so their points are irrelevant.
Don't confuse the limit equation definition with the result. Per the definition of the derivative, which is a "slope", it does involve two points that approach each other, but, in the limit, the result is for a single, defined point. Otherwise, you could never properly quantify a numerical derivative. Refer to for the description.
TTFN
faq731-376
7ofakss
Reminds me of an old joke about driving a moron crazy (put him in a circular room and tell him to urinate in a corner). Never thought I'd see the online equivalent. :)
I find this thread, like circles themselves, to be pointless.
We'd better knock it off, Kenat, or we'll be told to go stand in the corner.
it's not pointless (circles have an infinite number of points) ... but it may be corner-less
b'sides, it's silly season isn't it ? how is kate's pregancy ? (wtf cares ??)
Rats, the boss has us cornered. Wheel have to circle back to this topic later.
As this is a philosophical question, NOT an engineering one, it would be infinitely more appropriate to post it in a philosophy based site not an engineering one.
Pat
for site rules
"corner" implies a right angle"
So neither Icosoles (sp?) or equilateral triangles have no corners?
"Corner" implies a shift in direction, not 90 degrees - any percieved angle change.
I guess I'm using circuitous logic here...
Mike McCann
MMC Engineering
A circle is made up of all the points a particular radius from the center - no lines nor line segments at all - and therefore has no corners. The individual points are not corners nor is there any space leftover between them.
