Info about twostroke direct injection 2
lasse80
3
0
0
SE
Some twostrokes, as mercury outbords and aprilia mopeds, uses direct injection in order to lower emissions.
Where can I find info about this new technology./Thanks
You should check out the work of BRP (Bombardier Recreational Products) with the Evinrude ETEC Outboard engines. They are currently the most advanced DI 2-stroke engines available. These engines meet the most stringent emissions level (CARB 3-star). You can check out their website at There are several SAE papers available, including:
2004-32-0011
Carbon Monoxide Emissions From Marine Outboard Engines
2004-32-0092
Life Assessment of Pm, Gaseous Emissions, and Oil Usage in Modern Marine Outboard Engines
2004-32-0039
Predicting and Optimizing Two-Stroke Engine Performance Using Multidimensional Cfd
2004-32-0013
The Effect of Fuel Spray Momentum on Performance and Emissions of Direct-Injected, Two-Stroke
Engines
2003-01-3103
Modelling of Air-Fuel Mixing in a Two-Stroke Direct Injection Engine
2003-32-0007
Optimization of the E-Tec Combustion System for Direct-Injected, Two-Stroke Engines Toward 3-Star Emissions
2004-01-2588 Development of Nasa High-Strength Aluminum Alloy for Use in the Evinrude Etec Outboard Engine
MD
lassie 80, Check these out:
Patents and SAE papers by Orbital are too numerous to list(numbering in the 100's each)
Currently Piaggio, Aprillia, Mercury Marine, Tohatsu, Nissan Marine, Suzuki, Peugeot, BRP offer production engines using Orbital technology.
Kymco and Bajaj will be coming out with production models this year.
Additionally Mercury, EP Barrus(Tohatsu) and Hirth Engines offer production heavy fuel engines using Orbital technology.
Orbital has been working on 4S GDI with Ford, GM, Saab, Mercedes, Holden, and many others.
Additionally Honda and Caterpillar(diesel) have filed patents for engines using Orbital technology.
Have a nice day, Tom
