Hajiwaji
- Jan 1, 2023
- 24
Dears,
Is corrosion inhibitors effective against pitting cased by H2S and CO2 for gas flowlines? The salt content is very low, so the line has low risk of scaling and under deposit corrosion. The ECE model gives around 20 MPY of maximum pitting rate and less than 1 MPY for general corrosion rate. Can we use NACE publication 01055 to calculate inhabited pitting corrosion rate? Then use the value as basis for the required corrosion inhibitor efficiency?
Thank you
Thank you
