Our engineers are working on design a two part bearing which will act to support a top box and allow it to rotate and self locate by lifting up via the bearing and dropping down via the bearing. The box would weight about 70lbs and the bearing would have a diameter of approx. 4 inches
We have run proto units in delrin which seem to work well but will be producing injection mold tools to run production with. We have some areas as thin as 3/16" or so and wanted to know what material we should run for producion that would ensure we wouldn't have failure of the part due to impact and cold wheather conditions.
If you had to recommend the strongest possibly material option, would it be some grade of Nylon, Delrin, or Polycarbonate? We cannot have failure.
Any help or advise would be greatly appreciated.
We would mold samples off the tool and run some testing to confirm the durability, but would like to strt with the right possible materila spec.
