Hey All,
Hope you are all good. I'm working on a beam-over-column connection with a 4" wide beam (W12x19). The beam has a 2 1/4" gauge, and I'm considering using 3/4" Ø bolts. Can you advise if this bolt size is suitable for this beam considering only the edge distance which is 7/8"? As J3.4 advises min. edge distance is 1" for 3/4"Ø bolts
Thank you for your assistance.
Thanks in advance!!
Thanks in advance!!
