Insert Flat Pattern in Drawing
billylecaid
14
I'm currently trying to( as the subject clearly stated :p ) insert a flat pattern in a drawing along with the 3 stantard fully formed view of the same part.
I've already create the new flat pattern instance in the family table of the fully formed part ... and I'm stuck.
I've read somewhere that I should be able to change the model of a view but I don't know to find that function.
Thank you !
I'm French Canadian excuse my English mistake.
Me Fail English that's unpossible - Ralph Wiggum
Billy, you can add/change the drawing model by going to the File->Properties->Drawing Models->Add Model(select your flat model)->Set Model(select the model you just added) and inset a drawing view as you normally do.
Thank you so much!
It did work perfectly!
