Inserting Bitmaps
AndyGro
17
Does anyone know if i can insert a bitmap onto a surface in Solidworks 2005, i am trying to create a ID Tag plate with a company logo on it.
If you have PhotoWorks you can apply a decal.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
(updated 8/12/06)
SW 2006 SP 4.0 / SW 2007 SP 0.0
Thanks for the replys guys,
I got my picture in OK, but the problem now is that the tag plate is a curved surface (attached to a pipe), when the curve is applied (FLEX feature) the model fails !!
It looks great flat but curved and on a pipe.....not so great
Any suggestions ?
A decal would be better for this situation becasue it would wrap around the pipe correctly if you use the correct mapping option (just like the tag or label would in real life). The decal will show in Solidworks and also in the drawing if you use shaded view mode.
Rob Rodriguez CSWP
President: Northern
(updated 8/12/06)
As it's curved I assume you are using a Decal.
The decal should be applied after the Flex feature.
[cheers]
