Ilanseran Ramadass
I have a small doubt on the tolerance of ID mismatch between Valve to Pipe Connection.
Since the Valve is having a ID of 308 mm, and the Connecting pipe to valve is having ID of 306mm.
How ASME Code or EN code allows to use this kind of mismatch in ID?
Which code I need to refer? Please help.
Thanks in advance
kind Regards,
R. Ilanseran
Thanks in advance
kind Regards,
R. Ilanseran
