Mitchel123
- Mar 6, 2014
- 12
Hi Guys,
I am trying to install NX6 into Windows 7. While installation everything goes well with no problem what so ever.
After installation when open NX6, The following application error appear " The application was unable to start correctly (0xc000007b). Click OK to close the application".
I believe the system is having problem while opening the software.
Please advise if there is anything I can do to fix this problem. I have already re-installed the windows and install all the updated Software's including Direct X, NET Framework etc.
Thank you
regards
Mitchel
Thank you
regards
Mitchel
