DoBetter
- Jan 7, 2013
- 8
Is there a way to pattern/instance a feature in a way that I can adjust ONLY the parameters of the instanced features? For example, I pattern a hole linearly. They are spaced evenly apart, but I want to change the hole size of only one hole, and not the hole that was used to create the pattern. This would help with some more complex geometry that I am working on to prevent having to create a new set of features for each similar feature.
Thank you
Thank you
