With regards to the calibration of the UT thickness Gauges, Coating Gauges, Pressure Gauges, etc. I have two queries:
- Is calibration needed every year? and which Standard states this interval?
- When reading a calibration certificate for a device or a temperature or pressure gauge, there are what is called error indications or uncertainties from a certain standard values. During real use of the equipment or gauge, shall we consider those indications and record the values after corrections?
Thanks and best regards,
