MEP.Learner
Hi Engineers,
I have a existing premise with Central Chilled water system, which is undergoing a major renovation / refurbishment work.
There is a portion where only existing CHW FCUs replacement work is carried out. Then here comes our problem, after the replacement work it seems that we can’t get the required CHW flowrate through this loop of CHW pipes, therefore affecting the cooling to this area.
This loop of CHW pipe is not the furtherest from Chilled water plant (in fact they are near). And other further area cooling is still working well.
So potential issues that might cause this:
-airlock in chilled water pipe
-faulty CHW valve that are stuck and not able to open fully.
-dirty Chilled water, debris in water due to the old building.
-other obstruction within the pipe.
However after many round of troubleshooting, flushing and purging of the water and air in the chilled water pipe, we still don’t manage the solve this issue.
Is there anyway to check the condition of the chilled water pipe or to pin point where is the exact location of blockage that restricted the chilled water flow?
Or please share your opinion on how to solve this issue.
Thanks.
Thanks.
