XR250
- Jan 30, 2013
- 5,867
Not sure if this is the right forum for this question. I am a PE who usually hangs out in the Structural Engineers Forum.
Anyhow, I'm building a house and the insulation contractor says i need to cover the back side of the insulation of my attic kneewalls with an air barrier (the attic is unconditioned). I believe he is referring this section of the IRC...
My question is that if this is the case, why would you not have to cover the top of the ceiling insulation batts? Seems like there is a hell of a lot more surface area there for air to penetrate.
Why is the wall different than the ceiling? If I have painted sheetrock on the interior surface of the kneewalls, how would air penetrate anyway?
Maybe it is to keep the insulation from pushing out into the space?
Thanks for your help.
