In the Morgenstern-Price method the ratio between the inter-slice (vertical) shear force and the inter-slice normal (horizontal) force is often defined by a half-sine function. So the ratio would be zero at both ends of a slip surface. Yet the normal force near the top of the slip surface approaches zero as tension cracks form. So the cohesive shear force divided by the normal force tends towards infinity rather than zero.
Shear isn’t as directly related to horizontal forces as the ratio suggests. Shear may be negligible beneath a gentle slope whatever the horizontal forces (it would be ignored beneath a non-sloping surface) and could much larger in parts of non-circular slips than in circular ones. We all know about tan phi as a ratio between the total shear and normal forces, but we don’t think it’s a good idea when cohesion is involved. Beyond Bishop, why doesn’t there seem to be a more rational method of slices based on finite element analyses?
