XR250
- Jan 30, 2013
- 5,841
I have a residential shower with the two surrounding walls stopping a few feet short of the ceiling. The walls do not attach to each other and one end of each wall is attached to an exterior wall. As such, one end of each wall is unbraced. I want to cantilever a 3 1/2x3 1/2" steel or engineered wood post up from the floor system below by sandwiching it between some joists (all new construction). When designing the cantilevered posts and subsequent moments in the joists, what would be a reasonable loading to apply to the post. If I simply use 5 psf on the shower wall, I only get a 35 lb. reaction at the top of the post. Does this seem like a reasonable design load? I could imagine some antics in the shower that might require higher design loads :>
