Intermediate stiffening rings for storage tanks
MikeG7
199
Hi All
I am working with a fabricator who prefers the use of rectangular section stiffeners made from plate.
My question is that this is not shown on Figure 5.24—Typical Stiffening-ring Sections for Tank Shells . This shows bent up sections and angles.
Is this acceptable to use this type of stiffener if it meets the section properties required by the code?
Mike
See 5.9.2, which seems to allow some latitude in the shapes used, not just those in the table.
Note the requirement in 5.9.5 and the similar limitation on Le, Figure F.2, Note 3, which is of similar geometry.
