Internal sketch to a feature on NX10 2
jerry1423
I have an extruded feature, with the sketch internal to the feature, that is patterned.
I do not have the option to make the sketch external, even when I make the extrusion the current feature.
Has anybody else had the issue of not being able to make the sketch external to its feature ?
I am on NX10.
Jerry J.
UGV5-NX11
Yep when you do the pattern, you loose this option to make the sketch external. I had the same issue a couple months ago. I will have to see if I can find the information again.
Thanks for the support SDETERS
Jerry J.
UGV5-NX11
Sorry I could not find the information I had on this issue. It was about a year or so when I saw this pop up. And trying to search the GTAC solution site, has been terrible. Can't find nothing on there anymore.
Thanks Tomas, I did not know this. That is to bad, do you think they have a solution in for complying, with being able to search for issues? This has to be an extra load on GTAC.
