Hi All,
I have a box structure measuring 3000mm x 2500mm x 2100mm. This structure has 60mm walls, floor and roof with a thermal coefficient of 0.39. - 0.49 Wm/K
If I said starting point was with an internal temperture of 18 degrees centigrade and the outside was a constant -49 degrees centigrade, how easy would it be to plot the change in internal temperature against time?
I guess you could model something like this in cosmosworks but is there a formula that would work just as well if you ignored things like solar radiation
D
D
