ungarata
- Dec 10, 2012
- 17
guys;
i just started a new job, and they use Inventor here. I have 10 years experience with Pro/E, and (2) years experience with Solid Edge. we use Inventor 11 here, but i currently have 2013 installed as a demo to learn it; but in six days or so the trial period will expire and i'll install v11 (we're short on licenses so it'll be a juggling act). i went through a tutorial book, but that's about all i've done. here's a few questions:
while searching for other things, i keep seeing the discussions regarding visible work planes. this works differently in Inventor that what i'm used to; why is there such little emphasis on work planes/axes/points/etc? i typically will model a part using the datum planes for symmetry, etc. then, downstream, i'll use those part-level datums to help place and constrain my parts into the assembly, often using the assembly datums. somebody walk me through why Inventor shuns this, and what the best practice is for this...
another thing; i dont like how Inventor uses external sketches. i see it as extra steps to first create a sketch, then exit it, then perform an operation; it's a lot of extra work and clicks. other programs (Pro and SE) allow you to choose; you can use an internal sketch by default, or you can use an external sketch. Inventor, it seems, doesn't give you a choice. why is this?
I have a ton of other questions, but this is a good start for now...
-ungarata
-ungarata
