Inverter for 600KW 60Hz to 50Hz
MechGuy
3
What is the calculation to shift a sine wave? And who makes such an inverter in this size? Thanks!
i dont understand what you need?first of all most of the inverters are rated for both frequencies. only you have to change the setting. if you are buying one then you can specify first only to the manufactures. iam now talkingabout the incomming frequency. if you are talking of output frequency then you can change easy with the settings. pl be more specific in your question and i can help you
if you will be more specific i might be able to help you due to my exprience.
email to: raophir@hotmail.co/il
email to: raophir@hotmail.co.il
