EngStuff
- Jul 1, 2019
- 81
In the IRC There are limits that we are required to meet for wood shear walls.
One of the limits listed on Figure R602.10.2.2 "Location of Braced Wall Panels" requires a 10'-0" Max from corners and a 20'-0" max between shear walls.
Another limit is R602.10.2.3. which is to have 2 braced walls.
Now from my understanding, this is prescriptive.
I have a custom home, this home doesn't meet any of those limits. For example, one exterior wall has all openings besides only 1 small shear wall and it doesn't meet either limit. I assume there won't be limits if we were to engineer the shear wall and make sure the chord forces transfer into the wall. Also, to make sure part of the load from half of the diaphragm transfers into that one wall.
I am about 95 percent sure the answer is that none of those limits mater if we are engineering it? As long as we follow a few things about chord and diaphragm requirements on IBC and ASCE7-10 but want to see what the consensus is?
Also, from my understanding, This would be considered a flexible diaphragm with a ridged wall?
Thanks!
Thanks!
