IE22
- Jun 27, 2022
- 5
Hi All -
I have recently gone out on my own and am learning the joys of the IRC... I am getting requests for "Tall Wall" design as the building(s) in question has walls that are taller than the prescriptive methods of the IRC. I can wrap my head around the extent of my responsibility when it comes to vertical and out of plane checks on the individual pieces. Things start to get fuzzy for me when in comes to the global lateral design. Do I just need to be designing the shear walls in the offending line(s) as they are the "noncompliant portion" per IRC R301.3 or do I need to do a full lateral design including the diaphragm and its connections to the walls?
In my head I could come up with a building, with tall walls, that has less demand on a diaphragm than a building with short walls, but say high aspect ratios or long spans between shear walls. The latter would not require any engineering. So I could see an argument that full design of the diaphragm may be excessive. However the engineer in me is having hard time just looking away from some of the things I am seeing on the plans presented to me.
Thank you in advance!
