This may fall under the category of NFPA 79 which is
"Electrical Standard for Industrial Machinery". If so, can anyone reference it or tell me if there is a problem with the following scenario? A thermoforming, injection molding or any other industrial machine which is fed from a 480v busway feeder with equipment grounding conductor. Is there a problem with driving a ground rod 8 ft. into the ground and bond this rod to the machine? Can anyone who has access to NFPA 79 or from any other source tell me if this is necessary? Can there be any advantage or disadvantage to this installation?
