Is anyone using or know of anyone else using Schematic Thread display on drawings? 7
I have used it in the past, but only on board dwgs.
[edit]PITA
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
fcsuper,
Is there a CAD package that supports this?
JHG
The Simplified methods are trivial for 3D CAD as they can be generated from the hidden line removal algorithms on stand-in surfaces representing the thread minor and major diameters.
Some users are going full on with depicting actual cut threads on parts.
I recall the drawing style that was required for US patent drawings - I think those are no longer required; cannot imagine that the schematic threads are much used either.
I don't see a demand for the schematic depiction . I think I learned about them 50 years ago in a drafting class and never used them again in any mechanical design. Sure, they jump out and say "here's a screw thread" but so does a fully threaded shaded 3D model, which is it's own can of worms.
Like ewh mentioned I too used this in the past for hand drawings but I've never seen it on modern CAD drawings.
fcsuper,
I have manually done the simplified representation, particularly on section views, using SolidWorks. This will survive drawing updates. If the schematic representation were available, I would probably use it on occasion.
I would say leave it in the standard. Maybe some CAD programmer will implement it someday.
JHG
The Simplified representation conveys all the info needed. 40+ years ago, I used the Schematic rep in school but once in industry, only the Simplified was used and that even from the days of hand drafting. The Schematic rep is labor-intensive and provides very little benefit. I wouldn't use a Schematic rep even if the CAD system had that option. I use minimal hidden lines on the drawings I do and using a Schematic rep for threads would just create a cacophony of lines. The shops and engineers I work with have no issue with the Simplified rep, even when working with detailed mold design drawings. Everyone 'sees' the threads in layouts/drawings with the Simplifed rep without issue. But some may like the Schematic rep: to each his own . . .!
The last time I used it was when I did hand board drawings, maybe 30+ years ago.
Chris, CSWP
SolidWorks
ctophers home
I would like to see more thread sizes added to the SolidWorks library.
I think nobody uses schem threads is because there is no option for it.
Chris, CSWP
SolidWorks
ctophers home
Sorry, didn't mean it.
My thread on the issue already existed, I just was excited to see someone caring about both, SW and GD&T and actually trying to do something.
No worries. Things are starting out very very slowly with 14.6, but I'll keep these kind of issues in mind in our subcommittee discussion; and also when looking at SW products too. Thx!
Matt Lorono, CSWP
Product Definition Manager, DS SolidWorks Corp
Personal sites:
SolidWorks Legion
