Dear All,
I am in the process of designing a pig trap using ASME B31.8. However, the trap is being designed with C.A. (Corrosion allowance) of 3.2 mm and the pipeline has 0 C.A.
I am not able to find any guideline for designing traps in 31.8 is there an issue of having different ID between minor barrel in main pipeline. will this hinder the pig movement.
thankful for any help in this matter or any reference I should check.
