is it possible to use SA105 material for tube sheet in shell & tube heat exchanger ? 2
gh61
12
TEMA & ASME STANDARDS
thaks a lot
Yes it is, provided all requirements of Section VIII are met. It is no longer a B16 flange.
gh61, maybe, maybe not. What is the Code of construction?
Mike
No, you cannot use SA-105 tubesheet material for an ASME heat exchanger. Read ASTM A105/A105M.
-Christine
Which section? I can’t imagine that an ASTM standard dictates what an ASME BPV section can or can’t do.
For over 45 years, I have seen SA-105 specified for numerous tubesheet material in ASME VIII, Div.1 construction, especially in the 1970's and '80's.
Historically, SA-105 was not permitted for tubesheets and hollow cylindrical forgings for shells, per the SA-105 Scope. This prohibition is independent of Code of Construction.
Now, for Sec VIII, Div 1, starting with, I believe, the 2013 Edition SA-105 is permitted for tubesheets subject to certain conditiions, see UG-6(c).
I do not know if it is permittted for other Divisions or Codes.
So, maybe, maybe not, it depends on the Code of Cconstruction
Mike
XL83NL,
It's in Section 1.1:
"Tubesheets and hollow cylindrical forgings for pressure vessel shells are not included within the scope of this specification."
Note that there is also a weight limitation of 10,000 lbs.
-Christine
Correct. As mentioned by SnTMan, that doesnt mean VIII-1 excludes SA-105 tubesheets from it's scope.
SnTMan is correct, it looks like ASME Section VIII Div. 1 (and Section VIII Div. 2) were modified in 2013 to allow SA-105 material to be used for tubesheets as long as it meets the additional requirements of UG-6(c), mainly that an austenitizing heat treatment be performed.
One way of avoiding this issue is to specify SA-266 material when using carbon steel forgings as tubesheets.
Also note that SA-105 ASME B16.5 blind flanges cannot be used for tubesheets for ASME Section VIII Div. 1 construction.
-Christine
Christine74, for my edification if you please. Where is it stated that blinds may not be used as tubesheets?
SnTMan,
See Interpretation VIII-1-89-178:
"Question: May forged SA-105 blind flanges complying with ANSI B16.5 in pressure Classes 150 through 600 be utilized as heat exchanger tubesheets for Section VIII, Division 1 construction provided that both flange and tubesheet calculations are performed to verify that the thickness and bolting meet the requirement of the Code?
Reply: No. (See para. 1.1 of SA-105 for scope limitation.)"
-Christine
Christine74, thanks that's interesting. Perhaps the interpretation should be re-visited by any interested parties :)
Also note, that if using SA-105 to Section VIII Div 1 2019 edition, that the allowable MDMT is now warmer than in the past unless you normalize and use fine grain practice, so don't let that catch you out either.
