Nov 24, 2021 #1 Abu Ali Materials Jul 24, 2014 5 0 0 AE Hi IS term "machine bolts" mean that it should be partially threaded or it can be full threaded as well. Material machine hex bolt required as per ASTM A307. thanks in advance
Nov 25, 2021 #2 SnTMan Mechanical Jan 22, 2005 6,780 0 36 US Short ones, yes, longer ones will be specials most likely. Why not use studs? Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Nov 25, 2021 Thread starter #3 Abu Ali Materials Jul 24, 2014 5 0 0 AE Thanks SnTMan, Stud bolt are available this is different stock item where machine bolt stock is required. Upvote 0 Downvote
