Is Seismic Rho Factor use for foundation desgin 1
PEFLWI
120
ASCE 7 requires in certain circumstances that the seismic loads be modified by rho, thus Eh = rhoQe per 12.4-3. Is this amplification required to be transferred to the foundations?
I can't find anything that says it doesn't apply to foundations. ASCE 7-10, Section 12.3.4.1, lists elements that can be designed using rho=1, but foundations aren't one of them. Rightly or wrongly, I have always assume rho=1.3 applies to foundations for seismic design categories D thru F when using the equivalent lateral force method.
I hope this doesn't confuse but a previous discussion led to the conclusion that "Rho is only to be used where it is specifically stated that it is to be used". This may have been on a legal forum.
NEHRP's design guide for the seismic design of mat foundations (Link) instructs designers to apply rho. See the last paragraph below.
BUGGAR, aren't you thinking about Omega and not rho?
faq731-376
