Is there a good tutorial on transformer vector group change using cable phase swap and rollover? 3
electrical429
51
I understand transformer vector groups, however I get confused when it comes to changing phase order outside the transformer to change it's vector group. For example the following statement:
"For this connection the outer HV phase conductors are effectively swapped, with phase Red connected to transformer terminal C and phase Blue connected to transformer terminal A. This needs to be repeated on the LV side of the transformer to obtain a conventional vector group. Swapping the conductors in this way reverses the effect of the transformer, achieving an effective Yd1 vector group from a Yd11 transformer. This is called a negative sequence connection."
or
"Similarly a Yd8 can be achieved from a Yy0 by rolling the conductors from R -> Y -> B."
See if this Link and image below can help.
Good day!
My humble tip...
Swapping two corresponding leads in the primary and secondary of a transformer will effectively change the functional vector group of the transformer. The nameplate vector group still remains the same.
To determine what is the vector group change, use the following:
New functional vector group = 12 - clock number of original vector group
Examples:
1. A Dy11 transformer will become a functional Dy1 transformer (12-11 = 1).
2. A Dy5 transformer will become a functional Dy7 transformer (12-5 = 7).
Hope this helps.
Regards.
Further, a Yd8 can not be formed from a Yy0 transformer. You can not alter the winding configuration no matter how you swap the transformer leads. A Yy transformer will always be Yy. A Dy will always be Dy.
