Is there a way to make extrude dialog remember the limits options set in the dialogbox
NXsupport
Computer
Apr 11, 2008
249
Hello All,
Iam on NX2306. I wanted to know if there is a way to retain the limits options that I set up in extrude dialog , that it would remember . Currently, after I click Apply, it resets it back to default. I have remember dialog memory turned on in my role.
Any tips and tricks would be really helpful
You mean the Start/End fields resetting to "Value" from other options like "Symmetric" or "Until Next"?
Don't think there's a trick here, other than writing and programming your own feature dialog for that.
I feel you on that. I've had similar issues. I think you might want to check if your preferences are saving correctly. Maybe try resetting your settings or checking for updates? Not sure if that’ll fix it, but worth a shot.
