Is there anyone in this community t
DaveTroke
Aerospace
Oct 8, 2021
1
Is there anyone in this community that knows how to fix a Series 2?
I had it for a long time and spent £1000 for it, however the suspension alignment was always a problem.
I'm curious as to how precise you need to be with the tweaks. The local garage stated that they have a height gauge that they would use in circumstances where the floor is not entirely level. I was simply curious about the size?
Thanks.
'Height' is not the issue as much as What the toe & camber changes are with ride height movements. This has to be done with fuel loaded and the driver in the seat. Lotii are notorious for having all 4 wheels follow a different path in life, including brand new ones. Net build carelessness.
Your garage ought to have an aligner that can measure & record all 4 wheel toe & camber changes when you pull own and push up the chassis. If they can't do that, find one that can.
"That's my opinion and I am unanimous with it" ...
