bdn2004
- Jan 27, 2007
- 799
We've discovered that the field wiring on some large power transformers CTs are wired with aluminium cabling. This is the wiring that goes from the transformer junction box to the 50/51 power relay. We are in the process of replacing it, as well as all of the wiring to the devices on the transformer. My question is...is there anything special about CT wiring? Can it be run with the signaling in the same cable? The digital signals are 120VDC.
Also, do shorting terminal blocks have to be used? There are no shorting blocks on the existing installation, although they are shorted to ground whenever they are worked on. There have been complaints about shorting blocks in the past and the electricians don't trust them. I just wondered if they must be used.
A sketch is attached.
