I've done several works applying ASME Sec.VIII Div.1, without U-stamping.
Here I am told that U-stamping is mandatory by ASME code.
Is U-stamp mandatorily required by ASME Code, or is it depends on the project(based on owner requirement/national regulation)?
If it is not mandatory, could I know the specific section where it says (such as U stamp MAY required, instead of SHALL).
Thanks.
Thanks.
