I am using autocad 2002. I want to click on an object and make all of the layers other than the object's layer freeze. Does anyone know how to do this or do I need to buy an extension?
;|Finds layer of selected object, isolates it by Freezing, and zooms to (0.9) extents.
User clicks OK when finished and drawings returns to original view.
LAYER FLASH ROUTINE|;
it turns all but selected layer off.
experiment with freeze but you may not be able to freeze the current layer, unless you change the "selected" to "current" first - can be done.
