Isolation Pads
Lars90
Industrial
May 23, 2014
10
Hi all,
I need to choose isolation pads for a vibratory bowl feeder, does anyone know the calculation process to choose the right isolation pad ? Thanks
Lars
Yes, but the manufacturer will happily help you through the process. Their technical sales engineer will probably have worked on such an application before.
Cheers
Greg Locock
Hi Greg,
Thanks for your feedback. I know that the manufacturer would be able to guide me in this, however, I would like to know how to calculate and find out which isolation pad would be the best for some of our machinery equipment. If you can tell me i would really appreciate your help. Till now i did my own research and found some good material however, I'm inexperienced in this area so certain things i'm not sure about them. Thanks in advance.
This document is full of formulas however, don't know which should i use to find out the best isolation pad for our machinery to reduce noise and vibration. Link
Lars
You need to know what frequency (or frequency range) your most problematic vibration is, or else you just fit the softest ones you can. This assumes that the vibration is structureborne and then radiates from the floor or the rest of the structure, which may or may not be true, and eliminating that poath may or may not appreciably affect the airborne noise.
The transmissibility equations on P3 are applicable if this theory is correct.
Cheers
Greg Locock
Hi Lars90s,
Doesn't your other, earlier post say you problem is excessive noise?
Thanks Greg. Hi Tmoose, yes its about excessive noise, that's why i would like to know how to do my calculations to find the right isolation pads for the bowl feeders, to reduce vibrations and noise. Do you know any good brands for isolation pads ?
Lars
Hi Lars90
I'm not sure some basic stuff has been determined yet. As Greg L pointed out the isolation pads would only help if a significant amount of the "noise" is the result of structureborne vibration from the bowl feeders causing the floor to vibrate and be an effective loudspeaker.
When Kneeling and feeling the floor near the feeders is there perceptible vibration? Depending on the frequency of the noise, the vibration of the panel or object making the noise would feel like a buzz or tingle.
The unaswered frequency questions RE; both vibration and sound would make me most reluctant to apply any treatement or correction. Batting while blindfolded results in very few base hits and fewer home runs.
What he's getting at is that you haven't shown that the problem is vibration transmitted into the floor. The pads will do very little for the sound radiated directly by the machines.
Cheers
Greg Locock
Have you looked at wire rope isolators to dissipate vibration? Again, you need some basic frequency/amplitude data to gain an engineered solution. Otherwise you fall into trial and error solutions. Look at Enidine, they make wire rope isolators for the military.
