isometric view in drawing
gatnact
67
0
0
I was wondering if anybody knew how to set "parts" to transparent in a isometric view of an "assembly" in a "drawing"?
Try opening the part and use "Edit Color". You can adjust the level of transparency there until the component looks like a wireframe view in the drawing.
kd1959
Solidworks 2007 SP3.1, PDMworks
4GB Ram,3GB switch
2x AMD Opteron 254,2x 19" Viewsonic
Quadro FX 3400
That is what I did. I was thinking of something more like a global transparency adjuster valve that would adjust all of the transparent items all at the same time. Befor I thought about doing this I was just putting an extruded cut to the depth I needed to see. I might go back to doing it this way.
