Isothermal compressibility & volume expansitivity 2
adesline
Chemical
PY
I am on a research project concerning refrigerants and I need to find relations in terms of pressure and temperature for Isothermal compressibility & volume expansitivity. Do u know where I can get those or do u have any?
Tabulated values of thermophysical properties for the common liquid refrigerants such as ethane, ethylene, propane, propylene, butane, i-butane, ammonia and R-22 can be found in the free NIST webbook tables. Values for their isothermal compressibility and cubic thermal expansion, can be inferred from the tabulated data.
For tetrachloromethane and others I think the CRC Handbook of Chemistry and Physics can be of help. [pipe]
Thanks a lot. Pls can you give me info on how to get them because I have not been able to access free tables before now (NIST).
Also would the information there be in form of values or a correlation or an equation. The last two would be most helpful for me.
Thanks again
From the data on densities and speed of sound at various P,T conditions you can estimate isothermal compressibility and thermal expansion.
The source I mentioned can be raised by asking
Press name => write name => condensed phase => search => fluid properties => choose units => select range => delete v in small square, and press for data.
If you need an example of how to estimate those properties just ask. Good luck. [pipe]
Thanks a billion!!! You are great. Please I would love to have an example.
Take, for example, liquid ammonia under 14 atm pressure and 30oC.
temp., oC Vol., m3/kg
29 0.0016751
30 0.0016795
31 0.0016839
Cubic thermal expansion, (1/V)(dV/dT)p:
(16795-16751)/16751=0.0026267
(16839-16795)/16795=0.0026198
Average:0.0026232/oC
Isothermal compressibility at 30oC, (1/V)(dV/dp)T
Press. bar Volume, m3/kg
13.5 0.0016797
14.5 0.0016794
The change:
(3/16797)=1.786*10-4/bar
The exercise could have been made also estimating the bulk volume modulus of elasticity via the sound speed and the density, but with larger deviations. The isothermal compressibility being its reciprocal. [pipe]
Kudos to 25362 for an excellent example of practical and profitable use of authoritative, available, & free engineering information!
Art Montemayor
Spring, TX
God bless you real good!!!!!!!!
Thanks!!!!!!
Ade
I am trying to calculate the pressure increase due to temperature increase of a fluid which is trapped in the pipiline under temerature increase. I know the P1 and T1, T2 and thermal expansion ratio of the fluid. Please let me know how to calculate the P2
To msmedesign, assuming the pipe is rigid, divide the cubic thermal expansion (1/V)(dV/dT)p by the isothermal compressibility
(1/V)(dV/dp)T at the starting conditions.
Here is an example for ethanol at 70oC with data taken from the CRC Handbook of Chemistry and Physics:
(1/V)(dV/dT)p = 0.00167/oC
(1/V)(dV/dp)T = 0.001593/Mpa
(1/V)(dV/dT)p / (1/V)(dV/dp)T = dp/dT =​
0.00167/0.001593=1.05 Mpa/oC= 10.5 bar/oC​
This is an approximate result since the compressibility is assumed at relatively low pressures, but it may serve as an indication of what is to be expected.
[pipe]
