Issue with Launching ProE
mhor
I have been having this problem for a while, but I can't seem to fix it. It first started when I started the license server and it began to consume system resources. It started a dozen or so files named ptc_d. I restarted the computer and tried to restart Pro/E and nothing happened the license server would start but would not launch the file ptc_d.exe, so naturally Pro/E didn't start. I called our IT department who fixed it, but could not or would not explain how they did it. Since this is a reoccurring problem I would like to know what is going on so I don’t have to wait on IT. Any help would be great.
System:
Win 2000
1 Gig Ram
2 P4 1.4GHz
You first can try looking in start/set up/control panel/FLEXlm license manager
you must have only one server daemon for proe
pascual,
Thanks for the help, but could you give me a little more detail on this I'm not realy up to speed on the licence manager yet.
in the FLEXlm license manager:
in the tab tap: you can start, stop and get the status of one server
in the setup tap: change the parameters of a server. In service name you can select the server to modify. And you have a remove button to erase the selected server. I thought if you have more than one server you must delete all of them but one.
this is the first thing you could try. I cannot explain you in detail all options but this is the "intuitive" explanation.
Thanks again for then help. Yesterday I was "lucky" to have the problem again. I tried your suggestion but that didn't help. Thanks again
