Iterations/Reanalysis
structured
16
Is it possible to define the number of iterations in SAFE V12?
I think Iterations can not be directly defined for the analysis. However, under nonlinear, longterm, cracked & uplift cases Convergence tolerance can be defined which may limit the iterations for Nonlinear cases. But normally these tolerances shouldn't be changed much as these will affect the solution accuracy.
IR
