Jacketed vessel bulging on inside
kwisatz_haderach
22
We have a jacket heated agitated thin film dryer in our plant . 6 months ago it bulged on the inside. We fabricated a new vessel and after running for 6 months, it again got damaged by bulging on the inside on 6 locations like a flower. What might be the reason for this? This vessel is empty on the inside with blades scraping the inside of the shell and outside it is jacketed and heated by 2 bar steam through spiral baffles. Please tell me your thoughts about possible reasons behind this? Is the thickness sufficient. Please tell me how to calculate the thickness for external pressure. I got stuck on the unsupported length since it is stiffened by spiral baffles.
See ASME VIII Div 1 2023 Mandatory Appendix 9 JACKETED VESSELS
(c) Where the internal design pressure is 15 psi
(100 kPa) or less, and any combination of pressures
and vacuum in the vessel and jacket will produce a total
external pressure greater than 15 psi (100 kPa) on the inner vessel wall, then the entire jacket shall be interpreted as within the scope of this part.
Depends whether ASME VIII applies in India....
And who knows what the original design pressure was for the jacket. It might have been 1 bar, but then run at 2 bar.... and failed at 3.
