jplay2519
- Oct 7, 2014
- 100
I have some 12" pre-engineered wood trusses that I have to provide shoring and jacking plan for. I don't like trying to jack a bottom chord at a panel point where diagonals come in (i'll run an analysis to see if the diagonals can handle it I suppose) or a between panel points. Is something like a parallel member under each truss approximately 4' long (length can be changed) then having your typical jack and beam perpendicular to push everything up work? The thought is to help spread the load out but I feel like if you hit the point load that parallel member won't spread the load much unless it's exponentially stiffer than the truss itself. Any thoughts? This is just a general question on procedure, i'll have to run loads and everything but some things just aren't good to do no matter what the loads say.
