Jacobian
kapmnit123
538
Dear Experts,
I have a bit of confusion regarding jacobian interpretation in finite element analysis.What does Jacobian signifies? Is this just a transformation matrix between two sets of co-ordinate systems or is it a measure of the deforamtion (streching/shearing) of a mesh element?
Any particular citation for reference?
Kapil Sharma
Hi Kevin,
Thanks for your reply.It was a good practical explaination of what i asked for.
My question was bent more on the academic side of FEA..Jacobian matrix is used for transformation between global and natural co-ordinate susytems (isoparametric elements) so does that mean that the determinant of this matrix and the jacobian (as stated in the blog article you refered) are same????
Kapil
A bigger issue in the bad old days of self-generated meshes, was getting a negative Jacobian, indicating that you had inverted the numbering convention for a given element (i.e. the numbering violated right-hand rule convention for the element's coordinate system).
You don't see it very much any more for typical automeshers, but...if you have weird geometries, with multiple hollows and reentrant curves...you'd be surprised at the error messages you can see.
Hi everybody!
No... the determinant of an element's Jacobian Matrix is not the so called "Jacobian" found in the FE sofwares. Although wikipedia says this, there is a little difference when we're talking about the Jacobian in the Finite Element Method.
Please, take a look at the post Meaning of Jacobian in FEA for further information.
