Java sample code, getsession doesn't work (Ubuntu)
lugan2
42
Hello, I was trying to use the UG sample testing Java code, InterOP.java, please see the attached code.
It compiles fine, but doesn't return the session's handler. (doesn't go through line 28, and throws a catch. the 'theUfSession' returns NULL);
Does anyone know how to solve it? It is due to environment configuration mistakes?
Many thanks!
 http://files.engineering.com/getfile.aspx?folder=e1bab7e5-2771-46d3-85c4-f85b798aad6e&file=InterOP.java
I presume this code gets compiled to a JAR to run outside NX?
Try running it from an NX Command Window. To open one of these use you start menu (see attached image).
Graham Inchley, Systems Developer.
NX6, NX8.5(testing)
thanks for the reply Graham. I managed to solve the problem. I didn't update the bash file so leads to the problem.
Now it works.
Thanks!
