Jersey Barrier 4
Awre
74
Does anyone have a standard detail(s) for jersey barriers as a retaining structure?
I realize they come in modular sections about 20 feet long. How they placed in continuity?
Is it better to dowel/ anchor the adjacent units together?
Or is it better to place them with 1/2 inch expansion joint? If yes, how the differential movement/ settlement will be prevented in this case?
adfo - I'm certain there are many websites for DOTs with standard drawings that fit your need.
Google jersey barrier moment slab and you will find several details and or papers on the subject.
Qshake
[pipe]
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
When used on highway projects, there is a test performance standard for Jersey barrier, NCHRP-350. See: The bottom line is that permanent installations need to be anchored to the slab they are sitting on. Temporary installations (relying on friction with the slab only) need to tied together longitudinally. Bolts inserted through eye bolts embedded in the ends of concrete modules have been used and there are various manufactured connections. Here is a brochure from JJHooks, a supplier:
[idea]
[r2d2]
From my experience, I have found there are NO normal ones. Seems like they are all over the board - from 2,000 lbs to 5,000 lbs any where from 6' to 20'
Some are simple rectangular shapes and some look like giant Lego blocks.
Many are used for counterweights or building retaining walls - like at nurseries selling sand and mulch.
Call around - you can probably found something close to what you need/want.
Thanks all,
It was intended to use these Jersey barriers as a retaining wall on the side of a pedestrian walkway instead of a cast-in-place concrete wall. It is not for a highway.
The barriers will be bearing on gravel base and soil. Is the long-term differntial movement or settlement will be an issue and what is the best way to connect the adjacent units. I liked the J-hook but it seems that it comes with the barrier units itself not a hardware to be installed with an existing Jersey barriers, I'll check on that! I appreciate any further feedback
If you can find the "Lego" blocks - they truly connect like the blocks - just not as tight??
As far as values - no clue. Maybe the mfg can help.
@selta: 3 feet
Thanks all for the great feedback!
