Nicolas Bussieres
I am looking for a simple safe and legal way to use Venturi type Ejector (Jet Pumps)with steam (150#) and water to produce hot pressurized water in Canada.
The system appear to work fine, the issue is that those device don't come with a CRN number and most provincial juridiction call it a pressure fitting type H and request a CRN (Canada Registration Number).
I am curious if any member found a CRN approved similar device or found a legal and safe way go around the CRN requirement, without having to encapsulate the injector inside a registered pressure vessel.
