Jet Turbine
peter2007
Agricultural
Sep 1, 2007
8
hi.
im modelling a jet turbine engine.its very nearly completed apart from a few minor niggles, which i cant seem to do_On the combustion i have a sheet metal rectangle with several rows of round holes in it, this is then rolled in to a cylinder which is fine, but i need the holes to be dimpled from the inside. can this be done? as i cant seem to do it. ant help appreciated
You won't be able to get a true sheet metal model of this, since it involves stretching of actual material which SW sheet metal won't do. You can create a different model by shelling a solid body, or try using the indent feature. If you are unfamiliar with these functions, check out SW Help.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
thanks ill try it that way, as i can get dimples in the flat part but once its rolled up they jusy appear next to the model and not actually attached to it.
I did a SolidWorks model of a turbojet engine once - a WREN MW54. You can still see a tiny image of it in exploded view at the top of the page
Anyway, I had the same problem. Couldn't get dimples around the holes in the combustor can, at least not using the sheet metal features. I spent almost as long on that one problem as creating the rest of the engine.
Steve R.
Peter,
Please post a picture link when you're finished. I would love to see it.
