Jib crane swivel joint 4
kaffy
188
Good evening fellow engineers,
I am looking for information regarding the swivel joint marked up in attached PDF. Is it just a hollow pipe with bolt going through it? or is it usually a pin inside a bearing and further enclosed inside pipe? Any information or breakdown of that joint will be highly appreciated
Thank you
Kaffy
 https://files.engineering.com/getfile.aspx?folder=342b03ef-8f7f-4ff0-b4d9-cebfbd1cc010&file=Jib_Crane.pdf
A snip from the documentation on this website:
It's a bad idea to just have a pipe and bolt because steel on steel sliding under load is a no-no in most cases.
Bronze bushings are the way to go here.
Thank you very much. Really helpful
kaffy
They sell these things. You can buy them out of a catalog, with a load rating.
