JIC fitting dimensions needed & tooling
onestout
5
0
0
I sourced out a hydraulic manifold that we need and it came back with the incorrect "flares" for the fittings. We use a -3 and -4 45degree JIC. Does anyone have a dimensioned sheet that I could use to check our parts from and does anyone also know where I can get tooling to produce the female end in my manifold. I don't deal with fittings to often so I'm pretty green with this and any help will be appreciated. Thank You.
Michael
For flared fittings, my favorite source is Parker fluid connectors. Go to then click on their fluid connector page. I believe most of these catalogs have a dimension sheet associated. They're a pretty good source for all fluid connectors, and with some looking, you can probably find a way to adapt to what you have (I've always been able to). Also, if you haven't already found it, SAE J514 covers tube fittings, and is a pretty good resource as well.
